  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Wireless/Cordless RF Headphones ?
Discussion in 'Headphones, Earphones & Portable Music' started by Mugged, May 4, 2005.
  1. Mugged
    Mugged
    Feb 2, 2003
    48
    croydon
    Hi i need to get a set of these anyone tell me what to and not to buy never ever used these befor so any advice (apart from dont buy some :D )
    welcome.
    Regards Mugged.........................
  2. Mugged
    Mugged
    Feb 2, 2003
    48
    croydon
    :hiya: :clap: :lease:
    Bump
  3. THE BOARS
    THE BOARS
    Nov 25, 2004
    3,868
    68
    +79
    hi mate dont know if this helps i just bought the sennys rs120 and there quite decent for the price only £40
  4. Mugged
    Mugged
    Feb 2, 2003
    48
    croydon
    Hi THE BOARS thnx for your reply where did you get them from ?.
  5. THE BOARS
    THE BOARS
    Nov 25, 2004
    3,868
    68
    +79
  6. Mugged
    Mugged
    Feb 2, 2003
    48
    croydon
    Hi BOARS thnx for ya reply saw them on ebay but was put off by this bit in the auction page " These products are mail order returns and are in brand new condition, They come with a 7 day RTB warranty " , but thats just my opinion good luck with yours. And thnx again for the info.
  7. jazzman
    jazzman
    Nov 21, 2004
    188
    Istanbul
    +5
    i was aiming for the rs 140 actually what did you get brw if any i believe there is another wireless which are told to be better the shennheisers but its infra there is review on www.goodcans.com but they are difficult to find in the net
    do you have an idea which one is the top or the line sennheiser the rs 140 ro rs 85 couldnt figure it out
    cheers
