Wireless Controllers
Discussion in 'Nintendo Forums' started by loonatic, Dec 30, 2003.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    I am thinking about getting wireless controllers for my consoles - 1 for each, others can still use the wired ones :D
    What do you guys have ? and would you recommend them ? or are they not as good/responsive as the wired versions ?
    Also how are they in terms of battery use ?
    Cheers, Lee
  2. Kramer
    Kramer
    Using this for the xbox.
    No problems so far & quite happy with performance/functionality. Not too worried about battery life - have 2300mA/hr rechargables if it eats alkalines.
    :smoke:
  3. Dan666
    Dan666
    Jul 4, 2002
    144
    I have a PS2 and Ive ordered the Hori Anashin 2 from PlayAsia.com. I chose this because apparently its endorsed by Sony.
    An alternative import model would be the Airstyle W-Shock.
    Ive also seen one in Dixons called something like 'Tournament'... I think the controller had its own charger and dock - which I thought was quite good.
  4. dj898
    dj898
    i use following orders.
    xbox - Cosmo RF wireless
    gamecube - Wavebird
    Saturn - turbo IR wireless
    DC - IR wireless (forgot what it's called)
    battery life is quite good on Wavebird and reasonable for Cosmo.
    I keep bunch of rechargeable batteries so it's not a big deal as I always have charged batteries around.
    cheers
  5. TheBigApple
    TheBigApple
    Dec 10, 2002
    664
    In my cage
    +13
    Another vote for the wavebird, nothing else I have tested on this or any other console comes closefor reliability.
    For PS2 I own a 4 Gamers RF pad and would not recommend it. For starters it's too big, the D-pad is unresponsive, the plastic it's made from has the most horrible feel to it, and if you leave it alone for 30 seconds it seems to go into a sleep mode. As you can guess this is not good after a cut scene has played, you get thrown into the action only to find the fire button won't work unless you warm it up by frantic button bashing. By which time your usually dead.
  6. Jason S
    Jason S
    I use the Cosmo for the xbox, no problems with it at all, when sitting about 4m from the xbox (and reciever) itself. It's also a similar size / shape to the S controller.
  7. Bonesy
    Bonesy
    Feb 22, 2002
    1,149
    Wiltshire
    +28
    wow, that really isn't very cheap, is it..
  8. Webbster
    Webbster
    I've got 2 wavebirds for the cube, can't really have wired ones coz the consoles behind where I sit, they're fantastic, not had any problem with them at all. Just remember to turn them off when not in use so you don't cane the batteries!!
  9. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    I use the Hori PS-2 stick and Wavebird. Looking for a Xbox solution that gives wireless to the headset also. Kramer does the controller you are using have headset ports?
    Regards,
    Neil
  10. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    I've now got a couple of the Pelican Eclipse wireless controllers for the Xbox. They're no good for Live, as the memory card slots are in the receiver, but they do work really well and are cheaper than most of the wireless alternatives. Come out at about £28 from DVD Box Office.
    IGN have reviews of three wireless controllers for the Xbox. Doesn't look like they've come across one yet that's any good for Live use with the headset.
    EffTee
  11. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    I'm not Kramer but can state that no it doesn't. Kramer is using the Logitech one, as I am, and unfortunately, as with all others I believe, the headset port is attached to the input lead and sits next to the Xbox - unfortunately.
    I too am waiting for someone to bring out a cordless controller with cordless headset (maybe bluetooth) option.
  12. Kramer
    Kramer
    Kramer's using the Logitech one becasue you are :eek:. Picked it up in Northampton before our journey home after playing with yours :smashin:
    I'm sure someone will bring out a "live" compatible wireless controller (Logitech add-on perhaps?) before long.
    :smoke:
  13. Kramer
    Kramer
    :rotfl:
    Yes you are :D
    I was simply stating that I'd acquired the Logitech controller after you gave me a go on yours, nothing more.
    It was actually meant as a compliment/thank you. I wouldn't have even thought about getting one if it hadn't been for you. I'd probably still be tripping over trailing cables now.
    So, just to clarify, nothing "touchy" intended, just being friendly & thankful.
  14. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Hope you're not suggesting I caused you to spend the money on one :eek: Although I always enjoy spending other people's money. best way isn't it? :D
  15. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    I just re-read and realised i had mis-read (mis-interpreted) so removed the post and added a new one (actually before you added the above). Sorry :blush:
    That's waht comes from reading a post too quickly and shows how easily text can be mis-interptreted. Double :blush: :blush:
  16. Kramer
    Kramer
    That's exactly what I'm suggesting :D
    In this instance though, I'm glad you did. Very happy with the Logitech :smashin: As I say, I'd probably be in traction now only for you having tripped over a trailing cable from my (wired) xbox controller.
    There's a pint here in my local waiting for you :smashin:
  17. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    +16
    Thanks for all the reply's and recommendations :smashin:
    Went to my local Comet just to get a look at the various pads and I think I'll be getting the Logitech versions for both XBOX and Playstation and a Wavebird for my Gamecube.
    I've not yet dared to try XBOX Live for fear of getting addicted so that's not a problem for me...yet !!
    Cheers, Lee
  18. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Good idea, cos you will. Wish I'd had that resolve before I got my Live account :eek:
  19. MarkR
    MarkR
    May 3, 2003
    1,845
    Somewhere in Kent
    +296
    I have just linked up with Live and cant stop playing Links 2004. I must have dedicted my whole holiday to the Xbox. I never thought Live would get me hooked as what it has!!!:mad:
