wireless controller fault????????
Discussion in 'Xbox Forums' started by blakemere, Jan 29, 2009.
  1. blakemere
    blakemere
    Dec 16, 2007
    200
    +4
    hi
    my wireless controller won`t turn on.when the button is pressed the 4 green lights blink rapidly ,even if you hold it down a while when it`s released it just switches off. this happens with brand new batteries aswell.is it faulty. any ideas please
  2. peahead
    peahead
    Dec 14, 2002
    3,138
    St.helens
    +447
    Try holding the sync button on the controller while 360 console indicator lights are spinning round.
  3. blakemere
    blakemere
    Dec 16, 2007
    200
    +4
    have already tried that one thanks.
  4. piros
    piros
    Mar 7, 2004
    3,090
    103
    Nottingham
    +408
    With the sync button pressed on the 360 console too?
  5. peahead
    peahead
    Dec 14, 2002
    3,138
    St.helens
    +447
    Have you tryed this method suggested on xbox forums.
    Turned off the xbox
    removed the hard drive
    turned it back on
    connected everything
    turned it back off and reconnected the hard drive
  6. blakemere
    blakemere
    Dec 16, 2007
    200
    +4
    sorted now fellas thanks very much for your help.......
