Wireless Controller Charging ...
Discussion in 'Playstation Forums' started by theshabster, Jan 10, 2008.
  1. theshabster
    theshabster
    Nov 15, 2007
    6,350
    Lancashire
    +471
    Can this be done once the console has been powered off - i.e. like the Xbox 360 allows you to do ?
  2. legend_of_chaos
    legend_of_chaos
    Nov 11, 2006
    1,237
    Leicestershire
    +364
    No, but you can plug the usb cable into your pc usb port and charge it that way if your pc is on.
  3. theshabster
    theshabster
    Nov 15, 2007
    6,350
    Lancashire
    +471
    What a shame - the 360 really was good for little things like that.
    Thanx for the info though fella.
  4. grumpyguy
    grumpyguy
    May 11, 2002
    251
    +9
    When in remote play mode, my ps eye is on, maybe if you put it in remote play, that you switch on over psp, it may work
  5. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    First guy was wrong as it can be done, is you put the PS3 in remote wakeup mode for remote play it keeps the USB ports powered, turn that on and you get charging whilst sleeping however there is a slight whir from the fan much like the fan in the 360's power brick to keep the PSU cool.
  6. legend_of_chaos
    legend_of_chaos
    Nov 11, 2006
    1,237
    Leicestershire
    +364
    I did not know that, as he asked if it would work when powerd off i was assuming he was talking about if the ps3 was turned off completly.
