Wireless connection.
Discussion in 'Blu-ray & DVD discs' started by Dizzymac, Feb 22, 2014.
  1. Dizzymac
    Dizzymac
    Feb 22, 2014
    Hi all,newbie here.I want to know how I can wirelessly stream video from pc/laptop to tv? Example I would like to stream Sky Go from my pc to tv,cheapest way please.Thanks :)
  2. SirTiger007
    SirTiger007
    Apr 7, 2007
    778
    46
    +204
    Hello,
    I'm afraid as far as I know, it isn't possible to stream Sky Go to a tv due to licensing restrictions. The idea is for you to use Sky Go "on the go" as it were, and if you're at a TV then you can use your Sky box.
    Sky have done it on purpose this way to avoid you being, for example, able to stream the football from a laptop to a mate's tv easily.
    You may, however, be able to do it with an HDMI cable. They cost £1 from Poundland and would be cheaper than any wireless solution.
    Hope that helps?
