Wireless connect button greyed greyed out
Mimen
Can someone help please
When I search for a wireless connection I can see the router. I put in the password but the connect button is greyed out
I've tried several times
noiseboy72
The TV is not recognising the password as valid. WPA passwords need to be a minimum length and it's possible you are entering the password incorrectly or using the wrong password. Check this first.
If the password is correct, you may need to change it to something longer that the tv will accept.
Mimen
Spot on thank you so much noise boy I just re-entered my password and connect button was on. I just made a second mistake. The router was was also connected the wired network.. Once that was switched off it all worked
