Quantcast
Wireless Card Speed
thedude
hi guys i bought this Addon AWP1750E Dual Band Wireless PCI Express Adapter
I have virgin broadband wireless speeds of 380mbps on my imac and phone.
I cant get better than 180mbps with it, its connected at a speed of 585 or 866 depending on wind...
any suggestions?
mdbarber
watch carefully, is the 180 actual throughput MBs or Mbs ? and what test method are you using to establish those figures?
thedude
Speed test via okala my mac is next to it and gets 380
It downloads from steam or such like at 18mbps so that seems right but I don't know why I can't get it to 380mbps or downloads of 38mbps
techquest
The spec of the card seems okayish, though not one I've come across until now. What windows version are you running?
EndlessWaves
You don't say what access point you're using but 866Mbps link speed suggests you're running on 5Ghz at 2 spatial streams & 80Mhz which is fairly typical and likely what your phone is using too. Does your phone/iMac report link speed?
180 on it's own is a reasonable speed to be getting over wi-fi but obviously if you're getting faster in the same location there's some problem.
Dropping down to 585 suggests there may be a compatibility issue with the modulation/coding. Worth seeing if you can find updated drivers for the card or updated firmware for the router.
thedude
Yeah spec seemed fine to be honest compared to some others. im using windows 10 home edition
Christ thats technical! I do split my 2.4ghz and 5ghz down as reliability issues with sky q really help this.
i have this TP-LInk AC2800. Not sure what other settings ive done as im currently at work.
As for the compatibility yes there could be some i cant find updated drivers for the card.
Router i think is up to date.
thedude
Yes comes up with the Archer VR2800 on my network. I'll have a little look when i am home to see if that's the case.
And ADDONS site is so bad, if i hadn't built the pc and all id have just sent it back.
techquest
Yes it really is a joke when they can't even recognise the model of one of their own products. Why do companies do this!!!!!!
Will keep looking and look out for your updates later.
thedude
firmware is fine btw
thedude
anyone get any further?
techquest
Sorry I have looked everywhere for stuff on this but to no avail and the ADDON site and support really is the pits.
thedude
makes two of us
Similar threads
Trending threads
