Wireless camcorder mics
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dogtown, Sep 6, 2012.
  1. dogtown
    dogtown
    Oct 10, 2011
    703
    Northampton
    +48
    Do such things exist? I don't think a lapel mic would be upto the job as I want to use it for capturing loud music in clubs. I'd like to set the mic up near the dj then be able to go walkabout with my camera without the quality of the sound changing. Must be wireless!! Thanks
  2. 12harry
    12harry
    Oct 10, 2010
    4,760
    103
    London
    +387
    I think you'd be better off with a SDHC recorder and a dynamic mic as discussed earlier. Then you sync-up later, the camera may capture some local talent (customers) so having the camcorder monitoring "on the move" might give you some interesting mixing opportunities, esp. whenever the band concludes a turn, you should be able to create a far better "balance" between stage and audience applause, comments, joy, etc..
    Wireless mics are really expensive and can stop working due to electrical interference, etc. to be avoided unless essentaial, IMHO.
