I've recently purchased a Buttkicker BKA300-4 wireless kit. I've had one before which I bought from here which came with a UK power supply, but this one comes with the normal US power supply.
The amp is switchable between 115v and 230v, so I'm guessing I need to set it to 230v and change the fuse from it's current one to the one stated on the amp?
Which brings me to my next question, will I be able to change the power lead to one with a UK plug? At the moment it has one that says 10A 125V on it with a U.S style plug on the end but which doesn't fit into a normal travel adaptor. Will I be able to replace it with one like the type that plugs into a desktop PC, normal subwoofer etc. and what fuse would be recommended?
Many thanks for the advice for a complete novice electrical wise!
