wireless battery powered music system for bathroom
Discussion in 'Music Streamers' started by stevenn21, Feb 20, 2014.
  1. stevenn21
    stevenn21
    Jun 22, 2011
    55
    sowerby bridge
    i want to listen to music in the bathroom, in the uk there are no mains in the bathroom and i dont want to run an extension cord in as this is in violation of my tenancy agreement not to mention dangerous.
    must be battery operated!
    so ideally im after a battery powered wireless speaker that can be controled by a server (like jriver for example) and play the music on my pc via the server
    so i am left with a few options
    option 1
    a boom box geto blaster with a usb slot
    pros: battery powered, not too expensive
    cons: cannot connect to my network can only connect my digital music using the usb slot, would have to take it in and take it out everytime i used it, would have to load the music i wanted to listen to on to a usb stick. SQ unkown
    option 2:
    jongo s3 wireless battery powered network speaker (any other suggestions? )
    pros: battery powered, connects to my network using wireless technology, cam leave it in the bathroom permanently, no need to load music on to it manually as it connects to my home network,
    cons: no dlna so i dont think i can use a server like jriver to create playlists i dont know if cost is a downside as SQ is unknown(wireless sound isn't as good as wired in general),
    option 3:
    AS-TXRM Stationary Transmitter
    im not sure if this is appropriate or not?
    would have to buy Traveler® Series Speakers
    do any of you have other suggestions or advice or had any experience with these systems
    my system comprises of ca azur 551r receiver, azur 752bd player and the ca np30 network streamer the speakers are bx2's front matching centre with ca minx min21 as rears.
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,180
    +7,321
  3. LRV
    LRV
    Feb 11, 2014
    3
    4
    would a smart phone and Bluetooth speaker do the trick? Or even a speaker that physically plugs into the phone. When I was a kid we always had "the wireless" on bath nights.
  4. Cebolla
    Cebolla
    Jan 27, 2013
    1,707
    +279
    Ditto LRV & suggest an Android tablet or phone with battery powered speaker. With the BubbleUPnP app you can turn the Android device into a full blown UPnP/DLNA streamer/renderer, that can play your music files from a UPnP/DLNA server such as the one that comes with JRiver.
  5. stevenn21
    stevenn21
    Jun 22, 2011
    55
    sowerby bridge
    i like the idea of the the phone and speaker combo
    1.
    pros: can select a speaker of my choice to ensure better SQ,
    cons: would have to take phone in and out of bathroom when in use
    2
    Oasis Flow: Rechargeable Music Streaming and Radio System
    pros: can stay in bathroom
    cons: cannot chose speaker so cannot guarantee SQ
    option 1 could be cheaper depending on how much i spend on the speaker i own an android phone option two appears to do the same thing albeit an all in one solution.
    there are still some unknown variables
    1: SQ and connectivity
    2: wired or wireless speaker
    it needs to be wall mountable or fit on a 10cm shelf(i didnt realise these speakers got so big and expensive!)
  6. therixonator
    therixonator
    Feb 18, 2011
    553
    London
    +41
    You can have mains power in your bathroom, just not a 3 pin socket. I just cut the plug off a power cable and hard wired it to a flat plate with the box hidden in the plaster board wall behind. So now I have a Sonos Play3 in there, but you could use anything you like.
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Pure now support DLNA !
  8. stevenn21
    stevenn21
    Jun 22, 2011
    55
    sowerby bridge
    how good are the speakers?
  9. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Depends which one but had no complaints, can get you a good deal on them next week as just signed up as reseller
  10. larkone
    larkone
    Apr 21, 2006
    4,322
    134
    North Essex
    +1,211
    but they do not support flac according to the specs - bit of an ommission
  11. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Logitech Squeezbox Radio/UE with the battery pack.
  12. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,180
    +7,321
    Like the BT/phone suggestions it depends on his bathroom usage. If he's a clouds of steam type then he'll need something designed for the job like the Pure Oasis. Although a Radio has done my bathroom duties for a good few years now
  13. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    I use a Logitech UE boom for my bathroom, and it's actually not bad. It's about the size if a beer can with impressive bt range. Iphone doesn't have to be in the bathroom. The speaker is water resistant and I actually hang mine up in the shower cubicle. It's deffo worth a look and handy for outdoors stuff too.
    I use Ipeng to access my permanent library and playback.
    Also use napster and various radio apps.
  14. stevenn21
    stevenn21
    Jun 22, 2011
    55
    sowerby bridge
    it must play flac
  15. stevenn21
    stevenn21
    Jun 22, 2011
    55
    sowerby bridge
    yes its steamy
  16. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    My set up does IIRC, Logitech Media Server>Iphone with playback enabled Ipeng via wifi> bluetooth speaker.
    Not that I can hear the benefit of FLAC in the shower, on a mono speaker, connected via bluetooth.... its more of a convenience thing.
  17. stevenn21
    stevenn21
    Jun 22, 2011
    55
    sowerby bridge
    yes a lot of my files are flac
  18. niall campbell
    niall campbell
    Nov 16, 2007
    1,048
    48
    +66
    SolarDAB 2 SOLARDAB2 I use that radio , comes complete with a re chargeable pack included !!
    Then I use a 35 pence, 3.5 mm to 3.5 mm jack plug which goes into my iPhone headphone socket.
    I use an app called mediaconnect to stream music of my NAS hard drive to iPhone.
    My advice is to load your iPhone up with your favourite music and go into currys and check out the sound quality.
    If you have FLAC , then it has a capability of converting a CD to FLAC & MP3 at the same time in 2 different folders.
    You have to weigh up if the drop in sound quality is something you can put up with, and its only for the bathroom...................
