Wireless AV sender for Freeview - any recommendations?
Discussion in 'Freeview & YouView' started by badgerman, Nov 27, 2010.
  1. badgerman
    badgerman
    Apr 10, 2009
    407
    +24
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,147
    +7,093
    I'll alert Logiciel to this as I understand he has knowledge of what is available.
  3. badgerman
    badgerman
    Apr 10, 2009
    407
    +24
    Great thanks, reading his responses in the sky sections.
  4. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    Hi. You may have gathered from there that I recommend getting whatever 2.4Hz Argos are currently stocking as you can always take it back for exchange with another or for refund, if it doesn't work. Only when you've tried the range of frequencies they offer need you go for the more pricey 5.8gHz models such as the Nikkais. Also do check for possible causes of interference, anything from your router to the neighbours' babyminder. Small adjustments in locating the sender can often avoid these. HTH - Logi
