Wireless ADSL
Discussion in 'General Chat' started by Rad, May 11, 2005.
  1. Rad
    Rad
    Jan 31, 2002
    688
    Scotland
    +4
    Does anyone know of a ADSL service provider that will give you a wireless modem instead of the normal ones they give you.
    My friend wants broadband and wireless and doesn't want to have to buy the wireless kit afterwards.
    Cheers,
    Rich
  2. Rad
    Rad
    Jan 31, 2002
    688
    Scotland
    +4
    Anyone help ???
  3. dvdsubtitles
    dvdsubtitles
    try zen.co.uk - my mate joined up and they supplied him with a netgear wireless router. This is not standard - they charged him extra I think.
    The standard adsl modem is usually a cheap USB modem (an alcatel speedtouch I think).
    Hope this helps,
    Mat
  4. Rad
    Rad
    Jan 31, 2002
    688
    Scotland
    +4
    Cheers Mat, I'll get him to try them.
  5. seafoodmix
    seafoodmix
    Nov 13, 2003
    120
    when you order bt broadband 2mb the option is given for wireless at £xx extra.
    if you will be using the internet mostly off peak i wouldnt recommend bt the 0800 help numbers are shocking to get through to even in the early hours its at least twenty minutes on hold. then its reboot the machine and call us back. try another filter and call us back. reset the router and call us back. etc.
  6. dvdsubtitles
    dvdsubtitles
    Yeah BT and most of the well known ISPs are well known for bad support. Not worth it - smaller ISPs like Zen, Nildram or Pipex offer far better support.
    Mat
  7. w3dal
    w3dal
    Aug 4, 2002
    4,936
    Chelmsford, Essex
    +550
    just moved over to nildram. they will do u a deal with a wireless router, I decided to get my router elsewhere.
    So far been really impressed with them.
    Dal
