M
mjones0
I wanted to connect two PCs to an ADSL line with a router and wireless network, so my brother and I can play online at the same time. Im a bit unsure what I need and would be very grateful for some advice. Would this D-Link wireless router be okay?
http://www.dabs.com/products/prod-info3-info.asp?&m=y&quicklinx=2B9N
And then Id just need two of these wireless access cards?
http://www.dabs.com/products/prod-info3-info.asp?&m=y&quicklinx=24JR
One other thing, we want to split the bandwidth evenly so if one of us is downloading a large file it wont adversely effect the others ping. Is it possible to set it up so the bandwidth is split evenly and each PC can only use up to 256Kbps?
Thanks in advance for the help
