Wireless ADSL Modem/Router Recommendations
Discussion in 'Networking & NAS' started by RichardB, Jul 21, 2005.
  1. RichardB
    RichardB
    Sep 28, 2004
    34
    Hi, I'd like to setup a wireless network at home and was looking for recommendations on which hardware to purchase. Ideally I'd like a modem/router that I can plug my PC into via cable as well as wireless - the router is going to be next to my PC but I want to use the wireless for my XBox and possibly some other bits and pieces in the future.
    So, initially I think all I would need would be the modem/router (into which I wire my PC) and a suitable wireless access point for the XBox.
    Thanks - hope that makes sense
    Richard. :thumbsup:
  2. The Dude
    The Dude
    May 21, 2004
    6,283
    Beverley, East Yorkshire
    +2,602
    Netgear DG834 if you want a standalone Router/Modem (£45?)
    Netgear DG834GT if you want it with built-in wireless. (£80?)
    And about a tenner for an antenna upgrade, always worth doing whichever WAP you get.
  3. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    As a point of info, I spent a whole weekend trying to wirelessly stream ripped DVD's (vob) files from my pc to my xbox using a 108mbps SuperG connection and, well, failed, and sent all the wireless stuff back.
    It should be ok for for lower bitrate files like divx/xvid, and for a net connection. But it does depend on the environment, I am told, so you may not have the same problems as me. With the Cat5 cable everything just works properly, all the time.
  4. The Dude
    The Dude
    May 21, 2004
    6,283
    +2,602
    It's all down to the 50pence 2db Antennae that come with APs... :mad:
  5. RichardB
    RichardB
    Sep 28, 2004
    34
    Cheers for info - I'd seen the DG834GT on Dabs and it looked pretty popular and had good writeups. Think I'll swoop for that one assuming XBox can be hooked up to it.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Linksys WAG54G V2 (make sure you get a V2 V1 and V1.1 are "buggy") excelent spec reliability and perfromance dabs and ebuyer have them for just over £50
