wireless adapter for vista 64 ??
Discussion in 'Networking & NAS' started by chrisuk01, Jan 20, 2008.
  1. chrisuk01
    chrisuk01
    Jul 25, 2004
    534
    Midlands
    +16
    anyone know a good wireless adapter (usb pref) that runs properly on vista 63, as im using the zyxel, and the speeds are now very up and down. whereas before they were very stable
  2. chrisuk01
    chrisuk01
    Jul 25, 2004
    534
    Midlands
    +16
    anyone :(
    as the adapter i have \t moment is dricing me crazy, goes soooo slow.
    im uing a zyxel g202, and the drivers are no good. as speeds drop to around 20k after an hour
  3. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Assuming that you have a laptop, try using a PC Card (PCMCIA) rather than USB as they are more efficient with your PC's resources. Any good brand should be OK. I haven't found one better than another. Ensure that you have the latest Vista drivers.
  4. chrisuk01
    chrisuk01
    Jul 25, 2004
    534
    Midlands
    +16
    hi m8
    its a desktop pc :)
    anu advice for that plz ? :)
  5. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Yes use a PCI card. Even more efficient, especially if you get a Bus Master (which think that they mostly are these days). Just ensure that it comes with, or you can get, Vista 64 drivers for it.
