Wireless adapter and signal strength....
dave1de
Tomorrow I am planning on getting an adapter so im pritty much connected to live constantly. Just wondering though, does it have to be good signal strength to work perfectly (the same as wired).
My PSP has about 70% signal strength in the spot where the 360 is. Would this be OK, and do you think it would be stronger as the adapter has an antena?
My router also has an extend range and turbo mode feature....which I don't have switched on :confused:
Thanks:smashin:
runam0k
In my experience, the 360 adapter is very good. It picks up a signal a lot better than my laptop's wireless card.
You should only really worry if the signal strength drops very low/drops out.
70% on a PSP suggests to me that you won't have a problem.
