Quantcast
Wired or Wireless? Samsung UE40D7000
selector007
Hi folks i've recently purchased the above tv and i am pleased with the set so far. But what i find really annoying is the amount of times i am disconnected from my home network!!
My current set up is wireless, my tv connects to my dedicated HP server via my router which has windows home server installed. The wireless connection in my house is relatively strong. It is really annoying as i could be half way through a film and the tv disconnects from the network. I have even tried a static IP address but this has made no difference.
Is this a common problem with these tv's?
next010
Wired is always the way to go in a network, if you cant run ethernet cables then try some homeplugs as a substitute as they are still generally better than wireless.
Reception strength doesn't mean much, wireless is prone to all sorts of interference that can cause it to drop the link, it could also be the wireless isn't fast enough to handle video streaming which is very common.
selector007
Thanks. My next step is to try the homeplug route as suggested.
But what really annoys me is that i can play the same movies flawlesly via my iphone on the network(via wifi).
I guess i will have to try the homeplugs and see if that resolves the problem.
selector007
Just a thought i currently use a remote controlled plug socket to turn off the tv, could this have an effect on the wifi signal? I have checked the frequency of the remote controlled socket but it is 433.92mhz.
next010
Probably not, one thing you can try to stabilize the wireless is to set to one mode only instead of mixed a/b/g/n so try setting it to g mode only and see if that makes any difference.
