Hi folks - need a little help please!
I have a small wired network running via a Sky Netgear router, all operating through standard CAT5 cables. Attached is a ReadyNAS NV+ and two PCs. Until recently one PC was Vista, the other XP and all worked fine. Having replaced the XP machine, I now have two Vista machines operating. All units are set to a common workgroup name, and all use the router as DHCP server (on which the ReadyNAS is set to a fixed IP of 192.168.0.200). Problem is that I can only get EITHER the ReadyNAS OR the newer Vista PC to connect, and the Vista PC seems to take "priority". If both are connected, the ReadyNAS loses its IP address and says "No Network Link" while the associated light on the router flashes. I'm positive that the newer Vista PC used to work okay with the ReadyNAS because there are drives mapped across to it okay (this is all down at my parents, hence not sure when this happened or exactly what caused the problem). Any help much appreciated because I'm pulling my hair out here (and my next problem will be that for some reason the older Vista machine is now set to 10Mbs rather than 100, but first things first...!) Would love to resolve this while I'm here this weekend so please let me know what I can try or what additional anyone needs to help. Cheers,
Al
Al
