WinTV Recording (PVR 250) - Quality Settings?!
Discussion in 'Digital TV & Video Players & Recorders' started by DragonQ, Jan 18, 2005.
Tags:
  1. DragonQ
    DragonQ
    Hi, on my WinTV 2000 Application, when I go to change the quality settings for recording, it seems to work fine, but when I actually record it (say 1 mins worth) at DVD Standard Quality and DVD Extra Long Play (6400kbps 720x576, 4000kbps 480x576 respectfully), both have the same file sizes and appear exactly the same in Windows Media Player - the bitrate seems exactly the same, BUT, if I do a Right-click properties in Media Player, the Resolutions ARE different....but how can the file sizes be the same?! I want to choose a lower resolution to put longer amounts of Video onto DVD....but I can't!!
    Can anyone help?!
