Quantcast
Winter dashboard update caused E68 error
Carlosis
Yup, i downloaded the winter update on the 22-23rd of December and while i was navigating the new dash it froze, rebooted and got an E68 error.
I rebooted and it was fine for a few days then today it's come up again and won't go away.
I'd happily get a new harddrive but my 46 hour Skyrim save is on there! i HAVE to recover the save somehow, i enabled cloud saving after i saw the first E68 error but it has synced to a rubbish old save so would still lose about 30 hours.
Please, somebody say it'll be ok!
DJSigma
If you've got a transfer cable, you can try hooking the hard drive up to your PC and using XPort 360 (or similar) to get your Skyrim save off there.
Dinky Dragon
Moral of the story!
Backup!
DJs is the only method, it will work :p
Carlosis
Thanks for the replies. So using the Xport software can i put the save onto a 360 formatted usb drive and go from there? Now i'm off to the classifieds to seek a data cable!
