WinMCE to Toshiba LCD - best connection method?
Discussion in 'Microsoft Windows' started by Snash, Sep 6, 2005.
  1. Snash
    Snash
    Sep 6, 2005
    84
    9
    Having now completed my MCE setup I've got a cast iron excuse to go out and get a new TV - LCD of course ;)
    I've settled on the Toshiba 27WL56 and was wondering what the best connection method would be from my Connect3D 9600 card (VGA, DVI, S-VID) to the Toshiba TV: (connections from Toshiba website)
    Connections
    Fixed audio output
    HDMI
    Headphone
    PC compatible
    SCART: 2
    Composite video
    S-video
    RGB: 1
    Other specs:
    Visible screen size (cm): 68
    Screen format: 16:9
    LCD panel
    Screen Brightness (cd/m2): 500
    Contrast ratio: 900:1
    Resolution (pixels): 1280x720
    Resolution (row): WXGA
    Any thoughts? This is all a bit new to me so any input would be gratefully received.
    PS first post, great forums :)
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,268
    103
    +490
    Get a DVI to HDMI cable.
  3. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    Seconded.
    The picture I get on my plasma from my freeview tuner cards (Black Gold) by DVI > HDMI is streets ahead of my old NTL digital via RGB to component.
  4. Snash
    Snash
    Sep 6, 2005
    84
    9
    Cheers folks. Hutters it's the Black Gold freeviews I have in my system so I'm pleased to hear they work great:)
    What do you recommend for audio? I don't intend to use amps or anything. :confused:
  5. DaveP
    DaveP
    Just connect the Line Out from the Sound Card to the PC sound in on the tele.
  6. Snash
    Snash
    Sep 6, 2005
    84
    9
    As simple as that? Cheers folks for your help:)
