WinFast K7NCR18( Nforce2 )motherboards Help
Discussion in 'Computer Components' started by Peter J Roberts, Apr 9, 2003.
  1. Peter J Roberts
    Peter J Roberts
    Apr 4, 2001
    102
    Near Abington
    I've recently built the following Spec PC
    K7NCR18 Motherboard
    2500 + Processor
    Samsung DVD/CDRW
    60 gig HD (soon to be matched with another 40Gig HD)
    2*256 DDR Ram
    Sadly it keeps crashing with Windows XP pro
    My friend John (an IT Pro) Thinks it’s a driver fault and tried new M/board drivers + windows updates. But it still crashes
    He as also disabled the graphic drivers (using a default driver) which Helps (a little) but it still freezes and crashes.
    Also the speakers sometimes omit a Twanging sound (Like an Audio Crash).
    I Really Hate PC's and this is not helping I expected such a simple set up to work well!!!!
    Any Idea’s: mad:
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I have no experience of that particular MB but I had a frequent no ex-planation reboot problem with a board because the ram was in slots 1 & 2 instead of 1 & 3, not mentioned in the manual that this was the desired config...worth a try?
  3. Peter J Roberts
    Peter J Roberts
    Apr 4, 2001
    102
    Near Abington
    When I built this PC I used slots 1 & 3 but when John checked it (busi body) he changed to to 2 & 3.
    The manual says:-
    WinFastK7NCR18D/G-Pro Supports memory dual channel access. Please use DIMM1 + DIMM3 or DIMM2 + DIMM3 to get better performance.
    So you'd think no problem...... But since I changed it back no crashes ?
    Lets hope.
