WINDVD help please
Discussion in 'Desktop & Laptop Computers Forum' started by Greg Hook, Oct 20, 2003.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,608
    2
    In a secret location with Jennifer Lawrence
    +9,316
    Finally got my Ae100 showing wide480 as per my other thread on this forum but now have a slight windvd problem.
    When I play a DVD with WINDVD I don't get the image on both the projector and the monitor. On one I get the image and on the other I just get a blank screen in the windvd window.
    I only seem to get the DVD image on whatever I have set the primary monitor to be.
    Is there an option in WINDVD to make it play on both screens or does it just not do this.
    Its not really a major problem as its easy to change what the primary monitor is but I would prefer not to have to do it everytime.
    Greg
  2. vulkan75
    vulkan75
    Hi,are you using powerstrip?
    Theres options in there to set mulitple monitors.
    I might be wrong,but i think your monitors have to be using the same res,unless they are set right.
    so yr normal pc monitor may be out of range of the powerstrip set res, where as the projector isnt.
    I have a hs10 (1366x768)but when using tt my lcd monitor doesn't display the film,although i have had this workin in the past,I dont know how i did it.:(
  3. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,608
    2
    +9,316
    Thanks for the reply.
    I too had this working in the past, but after having to reinstall windvd once it hasn't worked since.
    I am cloning the desktop onto the projector so the monitor is the same res as the projector.
    I will try enabling multiple monitors in powerstrip to see if that works, but it seems to me as if its a WINDVD problem though.
    Greg
