WinDVD an Play HDTV .ts Files
Discussion in 'General TV Discussions Forum' started by Branxx, Jun 11, 2004.
  1. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I've tried yesterday and got WinDVD5 and WindDVD6 to play HDTV .ts files. The trick is to rename them to .trp.
    Up to now I was using VideoLAN but it was giving me some sizzling noise on analogue sound. With WinDVD the sound is crisp clear.
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    Also to get Windows media player 9 to use them, install the elecard mpeg player beta(though its the installed codecs you want) and then WM9 will play them and output to the spdif etc etc.
    Matt
