WinDVD 4 Doing my head in, please HELP
Discussion in 'Desktop & Laptop Computers Forum' started by petrolhead, Mar 6, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Busy building an HTPC
    Opp System Win2K SP3
    1 gig, 128M Ram, Radeon 9000, M_Audio Sound
    RageIII Tweak to set the resolution to match PJ (EMP TW100)
    The sticking point, so far, is Win DVD and the situation of region codes.
    It seems to be playing a DVD R1 but all I get is a black screen. Plays R2 oK. Can reset the region as per the DVD genie site and setting the registry entry, then re-booting.
    DVD Genie does not reset the Region Counter
    Reg Kill is worse than useless and I think this is a common problem with WinDVD.
    Am I wasting my time with WinDVD 4?. If so what seems to be the best/esiest to use re regions DVD Software?
    I must say that John Spicer has been very helpfull but even he relises that I am getting to the point of giving up and going back to good old reliable DVD player. Ok the picture will never be a s good BUT at least I can watch DVD without bursting a blood vessle :mad: :suicide:
    Any help would be appreciated
  2. feet14
    feet14
    Mar 13, 2002
    88
    UK, West Midlands
    Have you tried using DVD Region Killer? This fools windows into thinking you have a region-locked drive set to the correct region.
    http://www.elby.de/
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    feet14
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Region Killer works fine for me with Theatretek and my now not used PowerDVD.
    Why not do the Theatretek download, you have to pay for it so that you can try it, but if you dont register it within the seven day trial period then you can get a refund.
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Yes, John, I am considering that.
    I know someone with a copy. Is it possible that I could install their version for a test?
  6. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    john have you noticed any glitches in sound with theatertek. I watched my first DVD last night with it but lost sound every 5mins for a brief second.
  7. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Not with mine, check you haven't got antivirus running in the background or anything else for that matter.
    LMK
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Hi John
    Last night went to a friends house who also run a HTPC and sorted (X Fingers) my HTPC. Reinstalled the video drivers then Theatre Tek and Regin Killer and all seems to fine.
    The disk I had been using as a test was RPC R1 enabled (MIB II) and I think that was causing the problem.
    I would not play on TT until I inserted a non RPC R1 disk and then put it back in again and it worked.
    Also installed my IMAN and Girder.
    As yet have not tested on my own system but he has the same PJ so all should work.
    Thanks again for you help.
    When I regitser Theatre Tek and apply the patches I am hoping the RPC problem should go away.
    Peter
  9. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Hi Peter,
    I'll try a RPC disk later and let you know what happens with mine, not sure if I've ever tried one since I've been HTPCing.
    At least you've got things moving the right way.:)
