Windvd 4 audio problem
Discussion in 'Desktop & Laptop Computers Forum' started by fatrich, Jul 18, 2002.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,491
    halifax
    +31
    Can anyone please help, i have recently added windvd 4 to my other software dvd players which are windvd 3 and theatertek player, the latter 2 perform very well and are both very stable, i added the windvd 4 to see how it performed against the other 2 but i have no audio at all even though i have enabled the sp/dif to allow it to pass through to the processor, even with fiddling with the settings i still get no audio.
    I am using a m-audiophile 24/96 sound card and a radeon ve graphics card.
    The picture quality seem ok on the windvd4 it just bothers me that intervideo (to whom i e-mailed for support ) suggested that i went in to the player bar and select about !!! fat lot of good that is , there customer support stinks unlike the tt player
    any advise would be welcome and appreciated
    cheers
    richard
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Funny you should mention that, I've junked mine!
  3. pdweir
    pdweir
    I've got WinDVD 4 installed on one of my PCs, and it certainly doesn't pick up default sound settings nearly as well as PowerDVD XP.
    However, try this: in the audio sound options, select Analog out (and apply). Depending on quite what your set-up is, you should now hear a standard analog out. Then change setting to SP/DIF out (apply).
    For some reason, this works for me - SP/DIF now works fine.
    Now, if I can just work out why WinDVD 4 plays my dts audio cd about 5 or 10% too fast . . . ;-)
    Peter
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I tried messing about with mine, but it wouldn't pick up my spdif after that, let alone put sound out through it. I didn't get as far as finding out whether it played at the proper speed, just uninstalled it in a fit of pique...
