WINDOWS XP64 BIT & HARDWARE COMPATIBILITY
Discussion in 'Desktop & Laptop Computers Forum' started by drunkenmaster, Sep 13, 2005.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,567
    The Shaolin Temple
    +44
    Oh boy am I having problems. :suicide: Yes muggins thought my Mesh Pc should be preinstalled with the 64bit version rather than the normal 32bit and now drivers are limited for the various bits I have attached, especially my Viewsonic VX912 monitor, as at the mo windows only recognises it as a plug and play monitor and no 64 bitdrivers available.
    Is there any way to revert back to 32bit?, or would it have to be a fresh install?
    Or should I wait :rolleyes: until the 64 bit revolution :rolleyes: kicks off?
  2. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    To my knowledge there has never been a downgrade/step down option supplied by MS.
    In my experience, its a fresh install im afraid.
    I am suprised though, almost all hardware has 64bit drivers available at the very least as alpha tests. I´d do some serious googling looking for your missing drivers.
    best of luck!
  3. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    +139
    In fact, just a simple search on the Viewsonic website gives you THIS as a good start :thumbsup:
  4. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,567
    The Shaolin Temple
    +44
    :thumbsup:
    Thanks Monty - I tried the search but alas as they say - two searchers are better than one :rolleyes:
