Windows XP
Discussion in 'Plasma TVs' started by danny-p, Apr 21, 2003.
  1. danny-p
    danny-p
    Have Connected my pc vga to vga to my panny42 and to be honest am happy with the quality..
    Have left everything on standard but under settings you can reconfigure the monitor drivers which should set the screen to the correct resolution etc...But theres no Panny th42pw4b under panasonic?
    I was recommended to install a driver under Sony called GMD-W900.. but after installing there were no noticeable differences??
    Under Toshiba theres a Driver that says "panal 800x600"
    As the tosh is basically a rebadged panny i tried it but again no difference?
    Hope anyone can help.......Danny-p
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Best download a copy of Powerstrip. Then you can make up your own custom driver for it. There will probably be someone who can help you in the HCPC forum.
    http://www.entechtaiwan.com/ps.htm
  3. danny-p
    danny-p
    ReTrO,
    Will give it a try, thanks
