Windows XP Pro, is it any better?
Discussion in 'Desktop & Laptop Computers Forum' started by Frazal666, Jan 18, 2005.
  1. Frazal666
    Frazal666
    Hello. I plan on buying a new dell laptop for £930. For an extra £70, I can have microsoft XP Pro, or for £65, I can have 3.2GHZ and WSXGA (Normally 3.0GHZ and WXGA). Currently I have a E machines 1.1GHZ, 128mb RAM (I know, a big step). Is it worth sacrificing 0.2GHZ and a better picture for xp pro? What are the advantages? I will use two computers on one broadband connection, just in case that affects it. If not, how much is xp pro on CD? Thanks.
  2. watersa@ntlworl
    watersa@ntlworl
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Three main differences between Pro and Home:
    1) Support for dual-processor systems (Home supports HT)
    2) Software RAID 5 (Home supports 0 and 1 I believe)
    3) Ability to join a Domain (Home only joins Workgroups)
    If none are of interest then Pro is a waste. :)
    BTW, Home includes Backup, for what it's worth. ;)
  4. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    For nearly all home user and most work PC's XP home is more than enough. Your cash would be better spent on the faster kit.
  5. Frazal666
    Frazal666
    alright, cheers. I would have thought that pro does something to the performance of the overall computer. Spend it on faster kit then, Thanks again.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    It does .. makes it slower than Home 'cos it loads even more cr@p by default. :laugh:
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    My XP pro loads well quickly. I have theoretically some use for Pro though.
  8. theboyjb
    theboyjb
    I have read this often recently... but what exactly does allowing you to "join a domain" actually mean? Or is it the case that if I don't know, then I don't need?
  9. Blue_Max
    Blue_Max
    Nov 19, 2004
    167
    South Coast of UK
    +5
    theboyjb
    It is a term used in client/server networking.
    If you are a home user, "it is the case that if I don't know, then I don't need".
  10. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    As Blue_Max said, it's a rare home user that needs to know :).
    But by way of a small explanation, it's one way for a PC to be part of a LAN, how it can use files/printers on other PCs and how they in turn can access its' own files; Domains are used in a corporate envirnoment for administration and security purposes, home users with a small LAN will use a Workgroup, the old Windows 3 type of networking ... there once was a version of Windows called Windows for Workgroups (WfW), aka. Windows for Warehouses because it didn't sell when it first came out. :laugh:
    XP Home only knows how to be part of a Workgroup, it cannot log into a Domain.
    I was referring light-heartedly to the number of processes, services and drivers it starts up which are completely pointless for the vast majority of users. ;)
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I have XP Pro incase I need to network, I used an ethernet router for a while, before using USB to the ISDN box (more reliable).
    I am considering aquiring a server (from a customer who is XGrading), so this will be useful
  12. silentbob
    silentbob
    Dec 21, 2002
    122
    York
    +8
    This is not correct. Software RAIDing of any kind is not supported on either consumer OS'es. A real pain in the arse if you ask me.
    Also, the other main difference that noone has mentioned is the inclusion of Internet Information Server - which would enable you to develop and serve websites / FTP / SMTP services from your home machine. Good if you're a web developer.
  13. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Pro also allows you to encrypt folders.
    I can not see anyone at home having a domain controller, therefore for most uses (unless you need to lock and encrpyt things) XP-Home should suffice.
    To add to the confusion, The Inquirer has been reporting that Microsoft are planning NINE different versions of "Longhorn" (the next version of Windows).
    StooMonster
  14. Frazal666
    Frazal666
    so when is "longhorn" gonna come out? And have they mentioned any of the supposed 9 versions?
  15. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Allegedly in 2006 .. here's ZDNet's article which talks of seven flavours some of which also exist today if you consider Windows CE, MCE, Home, Pro.
  16. Frazal666
    Frazal666
    Heres an off topic Q, what is better out of Pentium 4 HT 3 GHZ and athlon ap3400+(Or something)? 64-bit got me interested in amd's proceesor, but P4 HT...
  17. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Much of a muchness I'd say for real-world use, certainly until there's some 64-bit software then the AMD is only usable in 32-bit mode. The 64-bit XP is out soon but then you'll need 64-bit versions of your favourite software, device drivers, etc. etc., I don't expect to see a 64-bit HTPC any time soon, not even sure M$ have annonced a 64-bit MCE before Longhorn.
  18. mjn
    mjn
    May 24, 2001
    22,124
    Herts, England
    +9,883
    I have 2 DC's :D
  19. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    It's available for download from various p2p file sharing sites at the moment. Not many people seem to bother downloading it though.
  20. watersa@ntlworl
    watersa@ntlworl
    My apologies, I know the backup utility is in the system tools on my Pro but where is it on the Home edition? thanx.
  21. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    :oops: .. the machine I was looking at is running Pro, last time I used it it was running Home, someone changed it and I didn't know.
    Apologies for the confusion. :blush:
  22. watersa@ntlworl
    watersa@ntlworl
    Damn :rotfl: I thought I was gonna find my home had it. Oh well nowt ventured.
  23. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    To be honest it's a pretty lame program, depending on your circumstances there are far better solutions.
