Windows XP monitor driver which has 50hz listed
Discussion in 'Desktop & Laptop Computers Forum' started by Peter Parker, Jan 24, 2003.
  1. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,177
    UK.
    +2,714
    Hi all,
    I was just checking my monitor driver and found that it caters for 43, 60, 70, 72, 75, 85 and a few others, but not 50hz.
    Being lazy, and not wanting to check each one or install powerstrip, can anyone tell me what XP monitor drivers include 50hz in it's list of capapble frequencies.
    Cheers.
    Gary.
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Hi Gary,
    I was using powerstrip with a HS10 last night at 56hz usinhg the standard windows plug and play monitor driver in XP with a Radeon 9500, all I had to do was to uncheck the box that said "hide resolutions that this monitor cannot display".
    Worth a try?
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,177
    UK.
    +2,714
    Thanks John,
    unfortunaltely, for my particular driver, it just hides the 43hz refresh rate. When unticked, I don't get 50 or 56.
    I can get the 56hz available in 800 x 600, but not 1024 x 768.
    This makes me wonder if any XP monitor profiles have 50hz in them.
    Any other ideas, or is Powerstrip my only option?
    Cheers.
    Gary.
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Powerstrip I reckon, bit of a learning curve to it but easy when you get the hang of it.
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,177
    UK.
    +2,714
