Windows XP monitor driver for Sanyo Z2
Discussion in 'Projectors, Screens & Video Processors' started by Bonzaimaster, May 15, 2005.
  1. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    I'm having a lot of problems trying to get my PC to display the Z2's native resolution (1280x720). My graphics card is a ATI X300.
    Windows XP automatically selects a plug and play monitor and detects that the display only supports resolutions up to 1024x768. If I try higher resolutions, I and a pan and scan display.
    I'm using the latest ATI drivers. I've also tried Powerstrip but my strong preference would be to get the correct monitor file for Windows XP.
    Any recommendations please?
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    What do you have your Z2 set to, i had this problem and i had it set to PC i think it is so changed the Z2s setting to HDCP, i think its called, and it worked fine, i then got a windows resolution of 1280x720.
  3. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    That seems to have done the trick. Many thanks for your help.
