Windows update... Am I thick?
Discussion in 'PC Gaming & Rigs' started by MikeKay1976, May 8, 2018.
  1. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    8,327
    +1,949
    So I turned my PC on and on the log in screen I have a Windows wupdate on the bottom right saying will take 15 mins and pc will be unusable. It has a restart now option and a postpone... However try as I might I can't get control of the screen my mouse is behind this screen. Return does nothing. I can log in but pc is kind of unusable as I can't get rid of this window which covers about 10% of the screen.
    I will try a reboot once all other updates are done but how daft is this? Has anyone else had issues with it? Thanks
  2. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    8,327
    +1,949
    oh dear i am so thick. spent 30 mins looking for a fix.... it is a firmware update for my TV.
  3. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,000
    +1,684
    At least you got it sorted [emoji39]
  4. alphaomega16
    alphaomega16
    May 17, 2005
    13,894
    163
    Southend on sea
    +3,635
    HAHAHHHAHAHAHAHAHAHAHAHAHAHAHAHAHA
    BEST
    THREAD
    EVER
    Glad your slight panic was nothing to serious though.
    Could be worse, you could be trying to figure out why your ******* PC won't turn on after building it only to find out after 10-20 minutes the good folks over at Zalman are big *****8* trolls and the power button on the front of the case is not hard wired all the way and comes disconnected as standard.
    Heads up on a little sticker would be great folks.
    It turned on via the motherboard and I was turning the power button connector on the motherboard in both directions and on both slots thinking they may have posted the names on the wrong sides but noooooooooooooooooooooooooo.
    Edit
    My specific post is here if you want to have a look at the connector picture yourself.
    The PC General Chat Thread
