Windows ReadyBoost Question
Discussion in 'Computer Components' started by phileastman, Feb 8, 2009.
  1. phileastman
    phileastman
    Jan 7, 2009
    12
    I have just seen windows readyboost and am thinking about using it. USB pens and memory cards can be used and i intend to use an SD card but dont know if all will work.
    Could i ask you to find a memory card that will work with a SD/MMC - MS/PRO memory card reader in my laptop
    My laptop is a Dell studio 17 which is here Dell Studio 15 Laptop Details
    I want to ensure it works with my laptop and can be used with windows readyboost. and to make it slightly more of a challenge i would prefer to spend under £10
  2. Lampshader
    Lampshader
    Oct 4, 2008
    512
    Cowbridge South Wales / Toulouse France
    +47
    i dont think thats going to work, it will be down the the speed at which the reader can transfer the data and i dont think it's going to be fast enough
  3. ntm1275
    ntm1275
    Nov 18, 2005
    586
    43
    +132
    I have an older Socket 939 AMD 4800+ X2 with 2GB RAM, and when I plug in my ReadyBoost capable 4GB stick, true be told, I cannot see any difference, or if there is a difference it is not noticable
  4. phileastman
    phileastman
    Jan 7, 2009
    12
    so can't the readyboost be used with an SD card? I watched a video online and it sold it to me because it showed it loading a lot faster. Truthfully my laptop is new so it only takes a minute to fully load
  5. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    Real guitars don't have strings, they have 5 colou
    +934
    You can use Readyboost with anything, but as Ready Boost doesn't really work on a Ready Boost certified device the effect is minimal.
    Readyboost only makes a difference if you are using more memory than you have physical memory in your machine, with Vista on 2GB you only use about 50/60% of your RAM anyway.
    An SD card is slow, so it wont be much different from paging to the HDD.
    Flash memory has limited Read/Write cycles, you would kill it really quickly with ReadyBoost.
    Your best spending £30 to put more RAM in the computer.
