windows movie maker - need to convert quicktime .mov file
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by ladybug, Jan 11, 2005.
  1. ladybug
    ladybug
    Ive recently started using my windows movie maker and i wanted to import a video file that i shot using my digital camera.
    When i play my video files on my computer usually, they are played in quicktime and are .mov files. I have not been able to play them in windows media player, although ive never really needed to.
    However i now need to play these files in windows media player to enable me to use windows movie maker. is there any way of converting the file (for free!) ??
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    Any file conversion is going to result in a loss of quality. Therefore I would suggest that you recapture the video from the camcorder as an AVI file. This is a 100% quality file of the origional tape. This is the standard format for just about all video editing but will take a lot of disc space.
    Mark.
  3. ladybug
    ladybug
    i shot the video clips with my digital camera, not camcorder. i then just transfer them the same you would a photo. they automatically play in quicktime player.
    therefore i dont really know how to (if i can!) do it as an avi file.
    am i able to do this on just a digital camera with memory card?
  4. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
