Windows Media Player
Discussion in 'Headphones, Earphones & Portable Music' started by RockerBug17, Mar 22, 2005.
  1. RockerBug17
    RockerBug17
    This may be a dumb question, but I'm a dumb person so it all works out.
    My Windows Media Player 9.0 won't work. Everytime I click it it says
    "C:\Program Files\\Window Media Play\\WMPLAYER.EXE is not a valid Win32 application"
    Now what the heck does that mean, and can I fix it or am I going to have to restore my computer, again?
  2. HMHB
    HMHB
    Nov 11, 2001
    25,620
    Nottinghamshire
    +3,981
    What version of Windows are you using ? WMP10 is now available for XP based systems so it could be worth trying that. I'm sure in the past that I've just re-installed WMP9 over the top of a current version of WMP9
  3. c0mplex
    c0mplex
    Try installing a new version. If problem persists, you should consider installing WINAMP...
  4. RockerBug17
    RockerBug17
    Where I can I find a download of WMP09?
  5. HMHB
    HMHB
    Nov 11, 2001
    25,620
    Nottinghamshire
    +3,981
    Go to this page and select the product you want to download
