Windows Media Player 10 problem
Discussion in 'Desktop & Laptop Computers Forum' started by mikeaitch, Mar 27, 2005.
  1. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    I'm using Media Player for my non DVD files on my HTPC.
    Problem is, when I switch to full screen, it reverts back to original size and won't display fullscreen images
    Anyone know how I can correct this?
    Tried removing through windows components then reinstalling WM10, but it's not helping
    Anybody? :lease:
  2. HMHB
    HMHB
    Nov 11, 2001
    26,717
    Nottinghamshire
    +5,484
    Have you had a play about with the settings in the View/Video size menu ? I'm not really sure what should be set there, but it's worth a try to see what the different options give you.
