Windows Media Player 10 - 'Media Audio' format?
Discussion in 'Headphones, Earphones & Portable Music' started by Tipsy, Mar 24, 2005.
  1. Tipsy
    Tipsy
    Feb 4, 2005
    37
    Im thinking of buying a NW-HD3 but looked through all my music on my computer today and realised that all my music, which i play through windows media player, is in 'Media audio' format, what does this mean? Does this mean that i can play it on a nw-hd3 or do i have to convert it, or what?
    Sorry if this is a silly question, cheers for the help
  2. HMHB
    HMHB
    Nov 11, 2001
    25,515
    Nottinghamshire
    +3,851
    If it's Windows Media Audio (wma) then it should be OK, although I imagine it will have to convert it to atrac3 to play it.
  3. Hasselhoffia
    Hasselhoffia
    Yup, SonicStage, the software you get with the NW-HD3 players, will automatically convert the WMA files to ATRAC format and then upload them to your player. Most of the tracks on my HD3 (about 5000 I think) were originally WMA files, and they sound fine after the conversion process, but I'm slowly going through and re-ripping these tracks from CD to get the better quality because I'm being fussy.
  4. jablakemore
    jablakemore
    Wish I could find it that easy. I have a few downloads from MSN Music Club (more fool me) in WMA format. When I try to put these over to my HD3 player it won't have it. Presumably the licensing restrictions on the music is putting my clampers on this.
    Please, is there a solution without having to go through a WMA to MP3 to ATRAC conversion?
  5. florist007
    florist007
    if u bought the music from any one but sonys connect music store u wont be able to put it on ur hd3 . ripping cds and **** is sweet though . its best bet .
  6. toots
    toots
    Be careful - the Sony doesn't play wma files - they are converted by SonicStage to ATRAC and then downloaded. If your files have any DRM or encryption (WMP defaults to these and older versions were worse) then you cannot convert them. The only solution is to rerip them all.
    Just sent my NW-HD3 back for this.
  7. Akasan
    Akasan
    Mar 19, 2005
    68
    Burn them to cd and then rip them from sonic stage
