Quantcast
Windows media connect problems
Incrediboy
Hi all!
Please read my problem and see what you think :)
I have previously had my computer streaming films (wmv) to my xbox360 with no problems. This was done via ethernet through a router.
Ethernet from pc to router, ethernet from router to xbox. All worked fine. No problems.
Unfortunately now, I have to have my pc on a wireless connection. The xbox 360 still is on a wired ethernet. The only problem is the xbox can detect my pc, but is not picking up any files that I am sharing through windows media connect?
Does anyone have any ideas?
Thanks,
Rick
Incrediboy
I've already done that, but thanks for the reply :)
bu5ter
windows meda connect has been replaced with the sharing in windows media player 11. I would make sure you are running 11 and then set it up through there. it will see it as a new device as the wireless card will have a different hardware address from the wired connection
Haizum74
When you open windows media connect does it have the 360 showing in devices????? I had a problem with mine too but just solved it
Similar threads
