Windows Media Centre won't recognise tvLINK
Discussion in 'Microsoft Windows' started by ian1944, Jan 14, 2008.
  1. ian1944
    ian1944
    Jan 12, 2008
    WMC insists on recognsing an IR control to complete configuration of a satellite TV feed. The standard Sky remote control 'tvLINK' is external to the TV tuner in the PC and there is no way that WMC can detect it or influence it.
    Is there any alternative way to control the (remote) Sky/Sky+ box or do I have to configure the TV tuner to think it's using an ordinary aerial and use two handsets to control my viewing?
    Any bright ideas would be most welcome ;)
  2. paulm187
    paulm187
    Mar 16, 2006
    628
    +80
    You need the the MCE IR reciever/blaster to configure the SKy set-top-box in MCE.
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    As Paul says it's not just any old IR receiver that is required but the correct Microsoft Media Center one. This is because when you are configuring a Set Top Box the IR receiver with IR bug is required to control the channels changing on the STB so that e.g. unattended recordings can be made.
