windows media centre 2005 info
Discussion in 'Desktop & Laptop Computers Forum' started by the klang, Jan 12, 2005.
  1. the klang
    the klang
    Dec 21, 2004
    449
    ilford essex
    +3
    can anyone help ?i want to get some hi def material to my plasma via a windows media centre.i know it plays hd-dvds at 720p (which is what i want)but also dose it upscale a standard dvd (pal or ntse) to 720p?the conection i can use from pc to plasma can be RGBHV or mini d-sub,because the screen has no hdmi or dvi inputs.any info would be great as i have very little knowlage of these things ....(yet).. ps...is it true you cant play hd-dvds from other regions?
  2. fugsi
    fugsi
    Dec 10, 2004
    27
    Xbox : will do the job
    look at this from america is all ready out there
    xbox with bigger hard drive with media centre extender not only does you can watch hd tv also turn your xbox into hd-recorder
    amazing video to watch 30 seconds long ...
    http://www.engadget.com/entry/1234000443025112/ :clap: :rotfl: :thumbsup:
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    As yet there are no HD-DVDs to know but it seems inconceivable Hollywood won't seek to re-impose customer controls which failed with DVDs, and with HD players it's highly unlikely it'll be as easy to get multi-region ones, I'm sure the likes of the DVD Forum and the MPAA will go after any manufacturer which provides a means to convert players to multi-region with all guns blazing.
  4. the klang
    the klang
    Dec 21, 2004
    449
    ilford essex
    +3
    cheers !ill keep looking.
  5. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,233
    116
    The Apps are Calling :-S
    +522
    I think there are some HD-DVDs as I accidently found a link to one the other day :rolleyes: , I would post the link to the DVD, but feel the mods might not be pleased :devil:
    PM me if you want the link, and by the way I don't own the dvd, so I can't comment on the quality!! :D
