Windows Media Center 2005, where can i get it!!??
Discussion in 'Desktop & Laptop Computers Forum' started by tim k, Mar 16, 2005.
  1. tim k
    tim k
    Please guys can you help me find a copy of WMC 2005 as i have a brang spankin new pc coming on the weekend and want to start it fresh with WMC 2005! I cant find it anywhere!
  2. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
  3. tim k
    tim k
    anyone know any cheaper solutions!?
  4. Rambles
    Rambles
    Jul 14, 2004
    10,442
    167
    UK
    +2,151
    Not legal ones
  5. Dave_M
    Dave_M
    Jan 31, 2005
    54
    Harrow
    Cheapest one I've found is at http://www.rlsupplies.co.uk/products/product.asp?id=3738
    You won't get much cheaper - basically you're paying for a Windows XP O/S from scratch as there's no upgrade path.
    BTW, you won't be able to buy it unless you buy some hardware at the same time as MCE is only available OEM.
  6. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    Except that, as Nathsea suggests, you can get it from ebuyer, where the price is less than rlsupplies.
    Also, most suppliers will count the MCE remote control as the necessary additional hardware and, therefore, charge seperately for it.
  7. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
  8. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    you can also pick OEM copies up at computer fairs
  9. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    Don't you also have to make sure the PC meets certain prereqs? e.g. doesn't it work with only certain graphics/tv cards, as opposed to any old PC?
  10. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
  11. DaveP
    DaveP
    be aware though that there is incompatible and "incompatible"!
    The Nebula card is not compatible with MCE but it does work OK using it's own software.
    Some other hardware just wont work at all. Plus, the compatiblity list is probably out of date as soon as it is updated.
    The best thing to do is check the manufacturers website for the latest drivers and see if they are MCE compatible. ATI, for example have MCE specific drivers for some of their cards.
    Dave
  12. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    my point being that you need to do this before you buy a new PC (that doesnt have MCE preinstall, and is therefore compatible), not start looking around for MCE after you have already bought the PC without checking compatibility (not that I am implying the OP did)
  13. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    it is a little cheaper @ http://www.scan.co.uk but you are not going to get it any cheaper. Remember as well that MCE is only available OEM so you are going to have to buy some "non-trivial" hardware at the same time. Most seem to allow the remote as the hardware else you can just get a really cheap network card.
    Also why MCE ?? There are many other alternatives out there which do the same thing and run under standard Xp (or Linux for that matter)
    Check out Media Portal which does the same as MCE (and more, e.g. it allows you to mix analog and digital TV cards) and it is free :D
  14. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    “Also why MCE ?? There are many other alternatives out there which do the same thing and run under standard Xp (or Linux for that matter)”
    Why because its cheaper than XP pro, works out of the box (MCE certified products) without too much setting up, the remotes are cheap and the results are very good.
    Media Portal, great product and looking better all the time
  15. MikeFish
    MikeFish
    A mouse counts as "hardware" to allow you to buy OEM software and they can be bought for less than £1.
