Windows Live Messenger removal help
Discussion in 'Computer Software & Operating Systems' started by WhiteLimo1988, Feb 11, 2009.
  1. WhiteLimo1988
    WhiteLimo1988
    Oct 29, 2006
    1,455
    +54
    hello again guys.
    so i went to go on windows messenger today, and as soon as i clicked it, it said that the 'program had stop working'
    i've tried un-installing it, but i can't find it anywhere on my list!
    i've gone into my program files, and deleted what i could then.
    now i re-downloaded the program off their site, and each time i go to install it it, says I've already got it installed. but i can not find it anywhere in my program list
  2. sunnybacon
    sunnybacon
    Mar 6, 2008
    3,267
    Leicester
    +433
    It sounds like it's half uninstalled, so that it thinks it's gone, but it hasn't.
    Try downloading Revo Uninstaller - it's freeware, and it should hopefully try and get rid of any remnants of WLM :smashin:
    Let me know how it goes :thumbsup:
  3. WhiteLimo1988
    WhiteLimo1988
    Oct 29, 2006
    1,455
    +54
    cheers for that, but no luck what so ever! really weird!
  4. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Which OS are you using?
    When you deleted it from Program Files, did it remove all files if not what was left?
    Have you tried doing Add Remove Programs and clicking Change -> Repair?
