Drongo
- Joined
- Oct 26, 2005
- Messages
- 6,088
- Reaction score
- 2,792
- Points
- 1,448
Well, there may be any number of reasons why the library scan is failing to complete. For example :
- There's a bug in your version of LMS
- There's something in your MUSIC library files that LMS can't handle
- The LMS database may have got corrupted for some reason
- Some other reason
So, it would be worth trying to determine what's actually happening first. If you open the LMS web page ("http://NAS-A0-BF-EA:9000" in as the address. This should open up Logitech Media Server's Web Interface (after a delay) and then click on the "Settings" button at the bottom right). On the "Basic Settings" tab there is a link underneath "Rescan Media Library" called "View Previous Scan Details". Click on that, and take a snapshot of the screen it displays and post it here.
Ok; here are the snapshots. Please forgive the multiple images; they reflect me scrolling down the screen
1:
2:
3:
At the bottom of that page are two further links, for "logitech Media Server Log File" and "Scanner Log File". Right click on the file names displayed, and select "Save Target As ..." and save the files to your PC (doesn't matter where, the Downloads library is as good as any folder). I'll PM you my e-mail address, and you can send me an e-mail, attaching those files (scanner.log and server.log), or attach them to a post here. They may give a clue as to why the scan isn't completing.
Ok; that's very kind of you. As much as I appreciate your help; I would feel very guilty if you spent too much time on a Sunday helping me.
I will look at scanner.log and server.log in a moment.
After you've done that, you could try doing a scan of the "Clear library and rescan everything" type (if you haven't done one already) and see if that completes. The normal scan is a "Look for new and changed media files type", which is what I assume you've been doing up to now.
I will try that shortly.
Once again; thank you for your help.
