Windows downloading instead of playing??
Discussion in 'Computer Software & Operating Systems' started by mc6701, Jan 25, 2008.
  1. mc6701
    mc6701
    Jun 30, 2007
    78
    +3
    Hi All
    For some reason when on a site with videos on and i click on them to watch them it downloads them instead of playing them in a pop up or in WMPlayer??
    It use to just open WMP and stream them........but now it downloads them before i can watch them. I am sure its something simple but cant find the answer anywhere.
    I am running vista and WMP11
    Anybody help??
    MC6701
  2. doodles
    doodles
    Mar 20, 2006
    424
    +25
    what browser you using?
  3. treacle
    treacle
    May 17, 2006
    598
    +16
    Try going back to WMP10.
  4. thelawns
    thelawns
    Mar 7, 2005
    1,665
    +146
    Is this all websites?
    At some point you must have been on a particular website and it asked if you if wanted to play in the current window or play in a new WMP window. It could be related to that but somehow it's downloading them rather than opening in WMP.
    Other than that, in WMP11 goto Options, then click on the Performance tab. Mine is:
    Connection Speed: Detect connection speed
    Network buffering: Use default buffering
    What is yours set at?
  5. thelawns
    thelawns
    Mar 7, 2005
    1,665
    +146
    Aah, it could be related to the file associations.
    Try going into the Options, then File Types and make sure that all the files you want to play are ticked...
    If that doesn't work then you could try going to the 'Set Program Access and Defaults' tool.
