Windows boot error
jetinder
First time i boot my PC i get to XP screen with the blue coloured bar in the centre.
Normally it goes from left to right and then i get my desktop.
But for the last 5 days on boot up the blue bar gets a 1/4 of way, then the PC freezes. When i do a soft reboot it boots up normally.
I ran a full viruse scan and that found nothing bad.
I ran Norton Utilities - Norton Windoctor but that never found this problem.
But what could be causing this problem and how can i fix it ?
F
flossie
have you tried pressing F8 after POST and selecting "last known good configuratuion". this will hopefully put right that has gone wrong without loseing any precious data.
jetinder
Thanks for your help :)
I tried that but it didnt work.
In the end i had to reformat my hard drive and re-install the whole lot which fixed the problem.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
