Hi All,
I just bought a new computer which came with a copy of Windows 7 Pro pre-installed, but obviously not activated (since i haven't purchased it yet), hence i have the nag screens etc.
I was wondering if anyone knew whether i could purchase an 'upgrade' version and use that activation key, or do i need a complete version?
P.S. If it helps, i had XP on my old computer (prob till have the key knocking around), so in terms of legality, if an upgrade would work, i assume there is no problem with only buying that.
Thanks a lot!
Thanks a lot!
