Windows 98 content crashes
Discussion in 'Desktop & Laptop Computers Forum' started by PhilipVass, Jul 15, 2004.
  1. PhilipVass
    PhilipVass
    When i attempt to type in my password to log in to Messgener it lets me insert the first character like this "*" then theirs a long 1 minute pause "....." then it suddenly finishes the password "...*******" with slight jerk, the mouse is also locking up allot and when i try to view a picture with Explorer it also does the same..half loads...long pause and sometimes crashes altogether, any ideas what i should do, is this a problem with my hardware or should i do a reinstall perhaps install Windows 2000 as a better alternative until i can atleast afford a decent PC?
  2. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,472
    What sort of error messages are you getting ? What spec is the computer ?
    It would be worth your while running a couple of free spyware checkers ie adaware and spybot to check that there's nothing nasty on your computer - likewise do a virus scan.
    Edit
    I've just noticed your thread about the sound card. Is that problem sorted yet as these 2 could well be related !
  3. PhilipVass
    PhilipVass
    I'm not getting any errors just freezes and crashes, i got a Trojan on my pc a few weeks back and thats with Ad-ware and AVG on it...
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    Use this:
    http://www.spychecker.com/program/hijackthis.html
    Hijack this will check your registry for anything abnormal and list the abnormalaties. You can the decide wether to fix them or not.
    I use Adware & Norton and got a trojan. They didnt get rid of it.
    Hijackthis did!!!
    I have even used this for PC's at work and peeps in my IT dept are gobsmacked at how good it is.
  5. PhilipVass
    PhilipVass
    I downloaded it...got an error message:
    A box saying
    ["Error Starting Porgram"..."/!\ A Required .DLL file, MSVBVM60.DLL, was not found]
    "[OK]"
  6. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Sorry not being helpful here but upgrade ! Windows 98SE gave me nothing but problems for years then I got XP and they all disappeared :)
  7. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,472
    Not sure if you noticed the edit at the end of my post ?
  8. PhilipVass
    PhilipVass
    XP won't run on this computer, but Windows 2000 will, i had M.E which crashed and no longer worked with my modem for broadband.
    Also this problem came after no sound, when i installed 98, i had no sound to begin with, would a reinstall help? or could my hard drive be damaged...
    also is it worth putting 2000 in until about Novemeber when i can afford a new PC?
