Windows 8 wiped off
Discussion in 'Microsoft Windows' started by Taurine14, Feb 21, 2013.
  1. Taurine14
    Taurine14
    Dec 27, 2010
    36
    11
    London
    Hey guys, I just brought a new samsung laptop and unfortunately it has come with windows 8, i have windows 7 on a USB stick and would like to take windows 8 off of the machine and install windows 7, how do i do this?
  2. Wild Weasel
    Wild Weasel
    Dec 11, 2005
    5,641
    The Medieval Warm Period
    +720
    I would first make Windows 8 recovery disks first, so that you can always go back to it if you need to sell it etc.
    Then you need to get it to boot from USB. I think you tap the Esc key as soon as you turn it on on a Samsung, then select USB from the boot menu. Get it to format the hard drive and then install to it.
  3. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
    Can I ask why you want to uninstall Windows 8 and re-install Windows 7. Windows 8 is far more performant than Windows 7!
    Trev
