Windows 8 Tips, Tricks and Deals
Our Year
Windows key: Switch between Modern Desktop Start screen and the last accessed application
Windows key + C: Access the charms bar
Windows key + Tab: Access the Modern Desktop Taskbar
Windows key + I: Access the Settings charm
Windows key + H: Access the Share charm
Windows key + K: Access the Devices charm
Windows key + Q: Access the Apps Search screen
Windows key + F: Access the Files Search screen
Windows key + W: Access the Settings Search screen
Windows key + P: Access the Second Screen bar
Windows key + Z: Brings up the App Bar when you have a Modern Desktop App running
Windows key + X: Access the Windows Tools Menu
Windows key + O: Lock screen orientation
Windows key + . : Move the screen split to the right
Windows key + Shift + . : Move the screen split to the left
Windows key + V: View all active Toasts/Notifications
Windows key + Shift + V: View all active Toasts/Notifications in reverse order
Windows key + PrtScn: Takes a screenshot of the screen and automatically saves it in the Pictures folder as Screenshot
Windows key + Enter: Launch Narrator
Windows key + E: Open Computer
Windows key + R: Open the Run dialog box
Windows key + U: Open Ease of Access Center
Windows key + Ctrl + F: Open Find Computers dialog box
Windows key + Pause/Break: Open the System page
Windows key + 1..10: Launch a program pinned on the Taskbar in the position indicated by the number
Windows key + Shift + 1..10: Launch a new instance of a program pinned on the Taskbar in the position indicated by the number
Windows key + Ctrl + 1..10: Access the last active instance of a program pinned on the Taskbar in the position indicated by the number
Windows key + Alt + 1..10: Access the Jump List of a program pinned on the Taskbar in the position indicated by the number
Windows key + B: Select the first item in the Notification Area and then use the arrow keys to cycle through the items Press Enter to open the selected item
Windows key + Ctrl + B: Access the program that is displaying a message in the Notification Area
Windows key + T: Cycle through the items on the Taskbar
Windows key + M: Minimize all windows
Windows key + Shift + M: Restore all minimized windows
Windows key + D: Show/Hide Desktop (minimize/restore all windows)
Windows key + L: Lock computer
Windows key + Up Arrow: Maximize current window
Windows key + Down Arrow: Minimize/restore current window
Windows key + Home: Minimize all but the current window
Windows key + Left Arrow: Tile window on the left side of the screen
Windows key + Right Arrow: Tile window on the right side of the screen
Windows key + Shift + Up Arrow: Extend current window from the top to the bottom of the screen
Windows key + Shift + Left/Right Arrow: Move the current window from one monitor to the next
Windows key + F1: Launch Windows Help and Support
PageUp: Scroll forward on the Modern Desktop Start screen
PageDown: Scroll backward on the Modern Desktop Start screen
Esc: Close a charm
Ctrl + Esc: Switch between Modern Desktop Start screen and the last accessed application
Ctrl + Mouse scroll wheel: Activate the Semantic Zoom on the Modern Desktop screen
Alt: Display a hidden Menu Bar
Alt + D: Select the Address Bar
Alt + P: Display the Preview Pane in Windows Explorer
Alt + Tab: Cycle forward through open windows
Alt + Shift + Tab: Cycle backward through open windows
Alt + F: Close the current window Open the Shut Down Windows dialog box from the Desktop
Alt + Spacebar: Access the Shortcut menu for current window
Alt + Esc: Cycle between open programs in the order that they were opened
Alt + Enter: Open the Properties dialog box of the selected item
Alt + PrtScn: Take a screen shot of the active Window and place it in the clipboard
Alt + Up Arrow: Move up one folder level in Windows Explorer (Like the Up Arrow in XP)
Alt + Left Arrow: Display the previous folder
Alt + Right Arrow: Display the next folder
Shift + Insert: CD/DVD Load CD/DVD without triggering Autoplay or Autorun
Shift + Delete: Permanently delete the item (rather than sending it to the Recycle Bin)
Shift + F6: Cycle backward through elements in a window or dialog box
Shift + F10: Access the context menu for the selected item
Shift + Tab: Cycle backward through elements in a window or dialog box
Shift + Click: Select a consecutive group of items
Shift + Click on a Taskbar button: Launch a new instance of a program
Shift + Right-click on a Taskbar button: Access the context menu for the selected item
Ctrl + A: Select all items
Ctrl + C: Copy the selected item
Ctrl + X: Cut the selected item
Ctrl + V: Paste the selected item
Ctrl + D: Delete selected item
Ctrl + Z: Undo an action
Ctrl + Y: Redo an action
Ctrl + N: Open a new window in Windows Explorer
Ctrl + W: Close current window in Windows Explorer
Ctrl + E: Select the Search box in the upper right corner of a window
Ctrl + Shift + N: Create new folder
Ctrl + Shift + Esc: Open the Windows Task Manager
Ctrl + Alt + Tab: Use arrow keys to cycle through open windows
Ctrl + Alt + Delete: Access the Windows Security screen
Ctrl + Click: Select multiple individual items
Ctrl + Click and drag an item: Copies that item in the same folder
Ctrl + Shift + Click and drag an item: Creates a shortcut for that item in the same folder
Ctrl + Tab: Move forward through tabs
Ctrl + Shift + Tab: Move backward through tabs
Ctrl + Shift + Click on a Taskbar button: Launch a new instance of a program as an Administrator
Ctrl + Click on a grouped Taskbar button: Cycle through the instances of a program in the group
F1: Display Help
F2: Rename a file
F3: Open Search
F4: Display the Address Bar list
F5: Refresh display
F6: Cycle forward through elements in a window or dialog box
F7: Display command history in a Command Prompt
F10: Display hidden Menu Bar
F11: Toggle full screen display
Tab: Cycle forward through elements in a window or dialog box
PrtScn: Take a screen shot of the entire screen and place it in the clipboard
Home: Move to the top of the active window
End: Move to the bottom of the active window
Delete: Delete the selected item
Backspace: Display the previous folder in Windows Explorer Move up one folder level in Open or Save dialog box
Esc: Close a dialog box
Num Lock Enabled + Plus (+): Display the contents of the selected folder
Num Lock Enabled + Minus (-): Collapse the selected folder
Num Lock Enabled + Asterisk (*): Expand all subfolders under the selected folder
Press Shift 5 times Turn StickyKeys on or off
Hold down right Shift for 8 seconds Turn FilterKeys on or off
Hold down Num Lock for 5 seconds Turn ToggleKeys on or off
Our Year
10. Windows-PrtSc: Screen capture
PrtSc has long been the default option for screen capture in Windows, but in Windows 8 there's a neat new twist: if you use Windows-PrtSc, a PNG file of the capture is saved in a Screenshots folder in your picture library. (If you don't want the clutter of lots of picture files, PrtSc on its own still copies the screen to the clipboard, and Alt-PrtSc captures just the active window in non-Metro apps.)
9. Windows-C: Charms
Think of charms as a kind of super-sized options setting: you can use individual charms to share with other apps, search for information, change settings, or send something to a connected device such as a printer or drive.
8. Windows-Z: App bar
The app bar is essentially the equivalent of right-clicking: use it to access additional options in Metro applications.
7. Windows-Q: Search charm
This launches search options for any Windows application: if you're in the store, for example, you need the Search charm to actually look for apps. Search is also accessible from charms (Windows-C), but using Windows-Q saves you extra clicking or arrowing around.
6. Windows-H: Share charm
Similarly, while you can access the Share charm (used to share information via email or to other apps) through the main charms list, this shortcut saves time getting there.
5. Windows-fullstop: Snap
This snaps a Metro app to the right, placing it in a narrow column so you can see crucial information (such as a Twitter feed) while working in another app. (By default, Metro apps take up the entire screen, which makes sense on tablets but can be annoying on large screens.) Repeating the key combination snaps to the left; repeating a third time maximises. To snap immediately to the left, use Windows-> (which is, in effect, Shift-Windows-fullstop).
4. Windows-Tab: Switch apps
The familiar Alt-Tab keyboard shortcut still cycles through open applications in the centre of the screen. If you only want to cycle through newer Metro applications, Windows-Tab is your friend, and switches in a list down the left-hand side.
3. Windows-D: Desktop
If you're not using Metro apps and want a more familiar Windows interface, Windows-D opens up the desktop.
2. Windows-I: Settings
This is a speedy route to system-wide PC settings. It's also where you'll find the Power button if you want to shut down your machine entirely (by default, Windows 8 favours putting your system to sleep rather than a complete shutdown.)
1. Windows key (on its own)
Hitting the Windows key on its own brings up the Metro desktop. However, if you then start typing Windows will begin searching (just as it used to on the old Start menu), finding apps, files and settings. You can also switch to searching other Metro apps from within the interface. You can navigate the results with the arrow keys and Enter, so you don't need to use a mouse at all.
Hillskill
Moderator/Games Reviewer
Admittedly its not the prettiest thread to look at but for now, its a start. Will start getting things more in order/organized etc tomoz.
wolvers
My little guide on deleting the windows.old folder;
Just remembered the Windows.old folder that is created when do an upgrade of Windows, it can be really large. Once you're sure it doesn't have any files in it that you need to keep it can be deleted like this;
1. Win + R
2. Enter 'cleanmgr'
3. Select 'clean up system files'
4. Select the previous version of windows files and delete.
I also deleted the option of the new installation files which was another 2gb+.
