Windows 8.1 Pro Preview - Problems!
Discussion in 'Microsoft Windows' started by ODB_69, Aug 6, 2013.
  1. ODB_69
    ODB_69
    Feb 8, 2008
    12,851
    3
    2
    Englishman in Scotland
    +2,627
    Downloaded the 8.1 preview build the other night and now having issues.
    First of all Catalyst Control Centre no longer allows me to open it with the message:
    Catalyst Control Center cannot be started.
    There are currently no settings that can be configured using Catalyst Control Center
    Therefore the hook up to the monitor is fine but theres a border around when I hook it to TV
    The other problem is sound. I have it setup so sound is duplicated on the PC speakers and the TV (bypassing through an amp). Everything worked fine, just knock the PC speakers sound down/off and have it through the main TV, perfect for watching a film or big screen gaming.
    However since installing the update its duplicating sound within the PC so I have to turn off the Realtek sound and then it goes normal, however that's only on the PC, to get sound on the TV I have to change the settings totally
    any ideas? Even roll back would do
